Restoration & Repair Tips Board
Case roof seal,
farmall kirk,
04-20-2008 05:25:37
I want to replace the seal around the roof on this 2670 Case,
someone put silicon goop around the edges and it look's totally hideous,
and on top of that,,, it leaks thru the blower vents in the cab when it rain's,
Do i just go get a new seal and put it in?
I mean I know that the seal is a better idea than the silicon junk that's on there now?
Need a good place to get plastic parts like the blower vents and misc things, and i dont wanna go to Case new holland as they might be kinda high,
malcolm moore
04-22-2008 07:42:55
 Re: Case roof seal, in reply to farmall kirk,, 04-20-2008 05:25:37
I just restored the cab on my tractor and had a hard time finding gaskets and seals. A friend of mine recommended that I go down to an automotive supply and pick up a roll of the material used to seal windshields. It is a rubber based material that stays plyable like soft rubber, and seals quite well. It is far more cleaner than using the silicone that tends to discolor. I got mine in a roll and shaped it into the parts I needed, and have had no leaks yet.
