Restoration & Repair Tips Board
18 HP Old Murray Riding Mower..manual and info
Amy Stout
04-23-2008 08:19:50
We have acquired this older (probably 1974 vintage?) 18 HP Murray Riding Mower...the model number is 5-39004, and the date of mfg. code is 2164. We cannot find any information, even from Murray, about the mower, and it could use a new starter and coil. If anyone knows where we could find a manual and parts list, or knows anyone who works on them we would sure appreciate some information. Thanks so much. A. Stout
malcolm moore
04-24-2008 05:26:23
 where to find info in reply to Amy Stout, 04-23-2008 08:19:50
Go to www.partstree.com. I am a small engine mechanic and the have a lot of info and parts explosions on line by manufacturer, even for store branded tools (Craftsman, Lowes, Home DEpot). You will need the model, type, serial or code number off of the frame. The decks have separate numbers as well. Good luck
Amy Stout
04-28-2008 09:57:25
 Re: where to find info in reply to malcolm moore, 04-24-2008 05:26:23
Thank you so much. We actually did finally find the correct starter kit and coil for this mower, but still need the correct belt for the deck. Your help will make that much easier I'm sure! Thanks a lot!
A. Stout
