Degreasing equiptment
mitch
05-20-2002 19:56:51
how do you get all the grease and grime that cakes up on tractors and implements over years of sitting outside, you can get a putty knife and scrape it off but surely there is somethin' easier and faster
mitch
Ralph Butteris
05-21-2002 07:19:09
 Re: degreasing equiptment in reply to mitch, 05-20-2002 19:56:51
Here are the two methods I have used over the years to remove built up grease and dirt on equipment. (1) old way 1 part gasoline two parts diesel brush on to the area to loosen the build up. Oh, by the way no smoking and do this in the shade it slows the evaportation. After 20 mins pressure wash the area. (2) New way better for inviroment. Get high quality Bio degradeable degreaser/solvent. Apply by brush or spray bottle; also do this in the shade, wait 20 min. power wash the built up area. Depending on how built up it is will determine how many applications of degrease and power washes needed.
TB
05-21-2002 16:05:36
 Re: Re: degreasing equiptment in reply to Ralph Butteris, 05-21-2002 07:19:09
I have used easy-off oven cleaner let set for 20 to 30 minuts in the shade and pressure wash off. It worked pritty well. It also hase the tendency to remove some paint.
Don
05-28-2002 03:34:26
 Re: Re: Re: degreasing equiptment in reply to TB, 05-21-2002 16:05:36
I use a water base detergent called "SIMPLE GREEN" and follow up with pressure washer with a good turbo nozzle.....
Dynaman
06-11-2002 16:50:20
 Re: Re: Re: Re: degreasing equiptment in reply to Don, 05-28-2002 03:34:26
Castrol Super clean did a fantastic job on my backhoe that had never been washed till I got it!!
Greaseman
06-30-2002 14:53:50
 Re: Re: Re: Re: Re: degreasing equiptment in reply to Dynaman, 06-11-2002 16:50:20
I like cleaning first with detegent and water takes alot off with minnimal abusive chemicals. then to Oven cleaner, then along with cleaning with detergent and water again.
