Restoration & Repair Tips Board
tractor labors really hard when the pto is on
charlie weible
04-25-2008 12:25:01
I surwish i had some information on why this tractor start fine drive and run fine also but when you put the pto on to kick the mower in motion its just boogs down, really labors hard well you just cant use the tractor i change all the fluids in the pto and put new in according to specs in the book. my tractor is a farm all lo-boy yellow not yellow and white seral no.is 17036J according to the book this tractor is a 1963. please put information here cant get to my email thanks charlie weible
the Unforgiven
04-25-2008 17:28:51
 Re: tractor labors really hard when the pto is on in reply to charlie weible, 04-25-2008 12:25:01
Hey Charlie, watch your governor linkage to the carburator when you engage your mower. I got a Cub last fall that acted just like yours, ran great but about killed it when you engaged the pto, it was not getting any response at all from the governor, and it turned out that the linkage was very worn. Worn-out governors are fairly common in old Cubs.
old
04-25-2008 14:02:37
But is it a PTO problem or mower problem. I would start by unhooking the mower and see if it still labors. If it doesn't then I would take a good look at the mower and see if maybe you have bearings or a spindle problem or even rope etc around the mower blades which will cause that problem. Also if it has a gear box check to make sure it has the correct fluid level in it
glennster
04-25-2008 12:54:12
could be a bearing is gone on the pto shaft, or bent shaft causing it to bind. with the engine off on the tractor and the pto out of gear, try spinning the pto shaft by hand, you should be able to turn the shaft by hand, there will be some resistance. if you cannot turn it at all, something is going on inside the pto, bearing ect.
