Restoration & Repair Tips Board
Bobcat 753
Mike Sego
04-25-2008 18:34:57
I have a 1996 Bobcat 753 with a hydostatic problem, The loader operates fine going forward & when I go backwards the loader pulls to one side, the right side pulls &the left side doesn"t.If anyone can help explain what is wrong with the loader I would really apprecieate it THANKS MIKE
JCSinGA
04-26-2008 04:41:14
 Re: Bobcat 753 in reply to Mike Sego, 04-25-2008 18:34:57
These later model B/C's have an aluminum lever (actually 2) that sits atop the drive pumps that takes your input from the steering sticks into the drive pump.
It's very common that these levers do not stay tight on the pump shafts first you have a little slop, then little more, finally it gets to where it wont move the pump lever at all.
If you find out this is the problem you will have to replace the lever, they have a bolt in them that supposedly keeps the lever tight to the shaft but if it ever gets loose motion in it you cannot tighten the bolt to compensate it (lever) must be replaced.
