Restoration & Repair Tips Board
piston running lean on M
bob 55
04-29-2008 07:03:23
I just overhauled the engine on my farmall M. the piston closest to the gas tank is looking very good. The next two are looking ok just little wet. But the one that is scaring me he most is the front piston...its a light brown chaulky colorlike its running lean. Can I make any adjustments to the carb? Is there anything i can do? I wonder if something didn't get put on right. thenk you for your help
james rumph
05-04-2008 05:33:26
 Re: piston running lean on M in reply to bob 55, 04-29-2008 07:03:23
A lean piston is a air leak [ lean condition] . With the tractor running at half rpm spray some starting fluid around the the intakes to see if the rpms go up. Do this on a cold motor so that the manifold is not hot.
There might also be a pin hole in the intake, it is cast iron!
If the rpm does go up then there is a air leak.
Some times a digital timing light with a tach in it is needed to see a rpm change due to the low rpm of these motors.
Another way but you would have to put a vacume port in the intake just above the carb or have a L.P intake on it. Put a vacume gauge on it ! At idel in will produce 12to 16 psi of vacume as rpm goes up the #s will come down to around "0" meaning the carb is jetted correct and meeting the demands of the motor .[ the "0#" you will only see under load] pulling a plow or on a dyno.
If that # doesnt come down then there is a air leak.
In short go buy some fresh intake gaskets and retorqe them after you have heat cycled the motor a few times.
Mike M
05-01-2008 07:49:34
Any that have any clean spots on the top would be where oil is coming up by them.
CNKS
04-29-2008 17:06:27
May not have that color with unleaded gas. But a light brown color used to be the way they were supposed to look. That may be your best cylinder -- ask on the Farmall forum for more answers.
rhouston
04-29-2008 11:55:44
Is the intake leaking at the Number 1 cylinder?
