Restoration & Repair Tips Board
300 utility - carb issues
Barnstormer123
04-29-2008 17:38:10
Hi, i'm not a pro, by any means, but recently pulled apart the carb on my IH 300 utility in order to diagnose a low fuel rate. Ended up finding a clog in the fuel intake screen/filter. I made new gaskets and put it back together...now i'm getting white smoke out of the tailpipe and fuel down in the air intake, it's leaking down into the big hose. Did i put it back together wrong? Float need adjusting? Any ideas?
old
04-29-2008 18:35:45
 Re: 300 utility - carb issues in reply to Barnstormer123, 04-29-2008 17:38:10
Made new gasket, WHY. You can buy a fair kit from NAPA or O'riellys for less then $20 and have all the parts you need plus instructions to do the job right. Sounds like your gasket isn't correct and or you have things way out of line/adjustment
barnstormer123
04-30-2008 07:18:49
 Re: 300 utility - carb issues in reply to old, 04-29-2008 18:35:45
because it"s easy. the gaskets are ok, i"m thinking there may be a problem with the float/needle valve, although they seem to be functioning properly. the fuel seems to be overflowing into the intake. next...looking for debris above needle.
thanks.
