Restoration & Repair Tips Board
grey fergie
Andrew Bondal
05-02-2008 17:29:40
This message is a reply to an archived post by robo on May 17, 2002 at 07:30:19.
The original subject was "grey fergie".
Check your clutch. We have the same problem. Firstly If it does make a grinding noise it will be your clutch. Firstly look down at the clutch. Underneath you will find a small plate that sticks of the clutch housing. Check that the clutch hits this plate. If not make sure the foot plate hasent been hit up. If this isnt the case then you must go inside and it will be most likly be caused by oil on the plates.
