Restoration & Repair Tips Board
Ford 3600 PTO Problem
piper451
05-04-2008 19:41:52
I have a 74" Ford 3600. The PTO shift lever will not stay in the rear or "engaged" position if a load is encountered while operating the tractor. Any sort of strain on the system will pop the PTO engage lever forward and out of gear.
Is there an easy fix to this problem that anyone is aware of?
Thanks.
soundguy
05-06-2008 12:52:53
 Re: Ford 3600 PTO Problem in reply to piper451, 05-04-2008 19:41:52
I'm not familiar with the pto setup on the 3600. but is there any in/out play on the pto shaft.. if there is.. it's part of the problem..
soundguy
piper451
05-06-2008 18:34:32
 Re: Ford 3600 PTO Problem in reply to soundguy, 05-06-2008 12:52:53
Negative on the in/out play. The lever is very "loose" going front to back though in my opinion.
soundguy
05-07-2008 05:03:27
 Re: Ford 3600 PTO Problem in reply to piper451, 05-06-2008 18:34:32
It should have a detent position.. might be the detent is bad. can you hold it engaged and have it work? If so check the parts diagram to see what you have behind the plate. and/or get a bunji cord to hold it engaged.. etc.
soundguy
