Restoration & Repair Tips Board
trans stuck in gear
GI FARMER
05-05-2008 09:36:10
I have a deweze hay mobale wagon ( small square bale mover) anyway it has a dodge 360 V8 and a 5 speed ?process? trans that right now is STUCK IN 5th GEAR. I took the top plate off and don't see anything obvious but still can't seem to get it into N any help would be great. Does anyone know if you can pull the trans from the bellhousing even though its stuck in gear? Thanks
Mark
Den N Ms
05-10-2008 16:11:58
 Re: trans stuck in gear in reply to GI FARMER, 05-05-2008 09:36:10
GI,Yes you should be able to pull the tranny out.But I would try to get it in neutral wit it still in there.With the cover off try to pry the 4th-5th slider to the rear while rocking it back and forth.Its the front slider gear.
