Restoration & Repair Tips Board
farmall 200
Cody butts
05-08-2008 13:51:18
I am 13 and restoring my first tractor it is a farmall 200 and it has a wide front end but at the worm shaft I have a leak (this is underneath the steering gear sitting upright) i am looking for some kind of kit or a fix solution the kit will need to have worm shaft seal, Gasket, Bearin cage cover gasket if you can find these individualy to that would be good thanks cody
RED POWER
CNKS
05-08-2008 17:19:22
 Re: farmall 200 in reply to Cody butts, 05-08-2008 13:51:18
Case-IH should have those gaskets and seals. If you use grease instead of oil it won't leak -- common practice, the gears won't know the difference. The Farmall forum is a better place to ask questions.
CNKS
05-08-2008 17:37:03
 Re: farmall 200 in reply to CNKS, 05-08-2008 17:19:22
I see you already did that.
Cody Butts
05-08-2008 18:03:40
 Re: farmall 200 in reply to CNKS, 05-08-2008 17:37:03
thanks sir
ill try both
