I have one of these. Mine has the 4 speed gearbox, and the forward/reverse lever on the column, with a go-nogo "clutch" on the left. I think they call this the shuttle transmission, but you cannot change gears on the fly, so I don't know. The biggest hassle with mine is road gear. 3rd and 4th are essentially useless unless I'm on level ground. On the slightest uphill, it just slows to a crawl. So, if I need to drive to my neighbors, it is a slow chore. There is a guy who has most parts for these at good prices- I found him on this site. I'll email you if I locate his info. Mine is a good machine and has served me well. I think it is not as strong as the later models that are dedicated backhoes. I have to get the angle just right with the digger arm in order to reposition the rear of the machine. The later models (starting with 580C I think) were lighter weight and were bachoes from the ground up. The 580B was built on a farm tractor. Right now mine has a very leaky bucket cylinder and apparently there are about 3 different packing kits that it might use- can't tell until it is apart. So I'll prolly just take the cylinder somewhere. Congrats on your purchase. Does yours have the extendahoe or the 4 in 1 bucket?
