Easiest tractor to restore
mc
05-25-2002 11:26:17
what is the easiest tractor to restore
Mr.Dennis
06-02-2002 04:10:35
 Re: easiest tractor to restore in reply to mc, 05-25-2002 11:26:17
Easiest would obviously be one from showroom or one which has recenly been restored.
howard
06-01-2002 17:46:31
if you are serious about restoring a tractor my advice(for what that's worth) is to see what kinds of tractors yor friends are restoring. you will need extra parts and advice and they will have both.
Dave_Id
05-27-2002 06:00:51
Farmall B without electrics would probably be one of the easiest, but don't we all want a challenge?If it was easy, then it wouldn't be any fun
Don
05-28-2002 03:20:04
 Re: Re: easiest tractor to restore in reply to Dave_Id, 05-27-2002 06:00:51
I look for a tractor that I like,that way you enjoy the results as you go along..... .I look for a tractor that runs good no smoke no serious oil leaks ...I don't like going inside to make repairs..... never been repainted....fairly straight sheet metal... Good enought tires on the back ....I don't mind putting on new front tires dress's them up fast.....a tractor that has been kept inside little or no rust..... that is about it.....expect to pay say $2400 instead of $1600,but in the long run it is money well spent..... .. the investment will be about the same and a heck of a lot less work and a good sound tractor.....I have done it both ways....don't try to cut corners to save money ,you will wind up with a piece of freshly painted junk.....I just bought a 1951 FARMALL "M"in this condition....I'll be driving it finished, better than new by fall.....
jake
06-02-2002 08:54:06
 Re: Re: Re: easiest tractor to restore in reply to Don, 05-28-2002 03:20:04
The old Fords are the easiest, all parts are available and reasonable. I have 2 Oliver super 55's, tie rod end in MI was $90.00, other parts obtained from CA to NY needless to say I get a Chrismas card from UPS every year.[ I do Have a Ford 2N which was the easiest resore]
