Restoration & Repair Tips Board
Case VAI Lower Gears
Klix
05-20-2008 05:55:31
I recently aquired a rebuilt Case VAI with 60" Woods Belly mower. It runs great but it would be more useful if it had lower gears (ie went slower)Are there any other transmissions/rearends/gears/ or kits that can be "swapped" into the VAI? Right now all I use it for is mowing the back field. I would love to be able to use it for some slower pulling jobs around the property. I wish my tractor had a "tractor gear"!!
VACLee
05-21-2008 19:14:58
 Re: Case VAI Lower Gears in reply to Klix, 05-20-2008 05:55:31
The bull and pinion gears as well as 2nd and 3rd gear are different on the VAI compared to the other VA series. Changing the bull gears will help some, but you will still have a big jump from 1st to 2nd. The VAI uses what is normaly 3rd for second and added a different ratio for 3rd.
