Restoration & Repair Tips Board
oil leak
Farm M
05-20-2008 17:14:34
I have a M working on restoring. Well there is leak. Where I think this leak is coming from is in the flywheel and clutch compartment. As you go to the rear is the transmission. You have the transmission compartment and clutch. It looks like there is a seam right where those two compartments meet. Thats right where it is leaking. Is there a seal there or what? If dont really understand what talking about. I will upload a picture.
Farm M
05-22-2008 19:12:49
 Re: oil leak in reply to Farm M, 05-20-2008 17:14:34
third party image
third party image
I have added few pics. The pic with circle yellow I believe thats what goes to the clucth and flywheel. That other shaft believe powers the hydraulic pump. I believe that oil leak is from the transmission because tranmission fluid is down plus the oil thats leaking out looks the same. The other pic was a cover took off it had this gasket like material. First off where do I get this at? It all most all rotted away. If the tranmission seal is out how go about replacing it?
soundguy
05-20-2008 21:40:41
Generally a leak fromt he clutch area is rear main seal.. or trans input shaft.
which are you loosing.. crankcase oil.. or tranny fluid?
soundguy
old
05-20-2008 18:09:03
I hate the term restore, because to restore something you bring it back to as good as it was new or better. That said you sound like your fixing one up. Any how it sounds like the rear main seal on the engine maybe leaking and to fix that you almost need to pull the engine and at least take the oil pan off and replace the seal
