Restoration & Repair Tips Board
cub cadet, won't start
chefbaker
05-21-2008 03:38:22
I have an older cub cadet 782 that won"t start. It won"t do a thing when the key is turned. i replaced the battery and still nothing. The fuses seem to be fine. It was fine when it was used last fall. Any ideas? Thank you
sbin
05-21-2008 13:28:04
 Re: cub cadet, won't start in reply to chefbaker, 05-21-2008 03:38:22
Hade the same problem on a 1225 and it was caused by the ignition switch.One of the connections rusted off.
I soldered a new connection on but saw the switch at TSC the other day for around $13.
soundguy
05-21-2008 12:03:10
In addition to what has been said.. I'd pull the start switch an ohm meter it..
soundguy
rhouston
05-21-2008 09:04:57
If it has any safety switches check them all. I'll bet it aleast has one on the brake and or clutch if there is one.
Mark W.
05-21-2008 08:56:27
Check all your battery cables, connections and ground.
