Piston sleeves farmall A
Jim M
05-26-2002 19:18:14
does anyone know any short cuts to removing the piston sleeves in the farmall A i have the head off the oil pan is off the motor is still in the tractor i am trying to knock them out from the bottom .but no luck have applies heat tryed to weld a few passes in the sleeve they are still stuck.Didnt want to remove the crank if not need to.thanks very much.Jim M
Murray Dunn
06-02-2002 04:06:07
 Re: piston sleeves farmall A in reply to Jim M , 05-26-2002 19:18:14
I do not think much of overhauling with engine in machine. This one is easy so lay engine on side.Insert old piston in upside down from top and rings will pop out below sleeve. Thake long bar and hammer and drive old piston and sleeve from bottom. You will damage piston but you do not need it anyway.
Jerry A.
05-29-2002 07:13:38
I've heard of guys packing the cylinder with dry ice to really cool it down and shrink the sleeves. Might want to add something Kroil or WD 40 to lube things up.
Rig up a puller or rent one. That's the easiest.
Good luck.
Red Dave
05-28-2002 10:19:41
When you say "i am trying to knock them out from the bottom" I hope you mean that you are trying to push them up from the bottom.
You probably need a sleeve puller. They are not hard to make, but you need a disk on the bottom of it that has an outside diameter the same as the O.D. of the sleeve in order to pull the sleeve out. I don't have a picture of one or I would post it for you.
You may want to post this question on the Farmall/IH board, somebody on there may have an idea that could help you.
