Help with steering cylinder joint
Dynaman
06-11-2002 16:42:54
The tapered holes in my front axle housing for mounting the two cylinder end studs are shot. There is plenty of metal there to bore and ream a new hole to accept a sleeve I will machine and secure with a dutchman type setup. What I'm unsure of is how to fix the taper? Is a drill or ream with that much of a taper sold just for that purpose? The tapered stud on the cylinder end is also cooked, it has a ball on the opposite end for pivoting while turning. Are those end's available? Or has someone done something else in this situation. Thank you.
