Gauge repair question
Dynaman
06-11-2002 16:47:53
About half of my gauges don't work. Unlike the previous owner I refuse to keep them this way. They seem to all work with a hot attatched to the gauge and the neutral varies by the sender. My local (would like to call him advisor) told me to touch the sender wire to ground and see if the needle moves. It did and pegged off the gauge and stayed there. How does a person establish whether the gauge is bad or the sender? And also is my gauge ruined?? Thank you.
JMS/MN
06-12-2002 00:03:28
 Re: Gauge repair question in reply to Dynaman, 06-11-2002 16:47:53
If you peg the needle by grounding the wire going TO the sender, the gauge is ok, but the sender is bad.
Dynaman
06-12-2002 02:38:40
 Re: Re: Gauge repair question in reply to JMS/MN, 06-12-2002 00:03:28
Except now my needle is stuck in the pegged position?
hammer
06-14-2002 05:21:26
 Re: Re: Re: Gauge repair question in reply to Dynaman, 06-12-2002 02:38:40
usually a slight whack on the SIDE of the gauge with the handle of a screwdriver or eq. will do the trick.
hammer
06-14-2002 05:21:03
Dynaman
06-14-2002 12:58:28
 Re: Re: Re: Re: Gauge repair question in reply to hammer, 06-14-2002 05:21:03
What your saying is it's not ruined? I thought I probably overextended the needles travel. What would reversing the polarity do??
Joe (Wa)
06-14-2002 22:47:08
 Re: Re: Re: Re: Re: Gauge repair question in reply to Dynaman, 06-14-2002 12:58:28
Dyna, Your working with mild inductance here, reverse polarity probably won't have any effect if it is stuck. Hammer has the answer (but gently, OK) Joe
