Help with patching a gas tank
Trueby
06-16-2002 21:15:27
We have patched the gas tank on a 1925 fordson three times with JB Weld. Cleaned the area as the directions said, made the patch very wide to cover hole. Is there a better way to patch a leak? Any help would be great. Thanks you in advance
Trueby
Gene Davis
06-19-2002 18:39:51
 Re: Help with patching a gas tank in reply to Trueby, 06-16-2002 21:15:27
Do a web search for "POR15" They have a very good product line for this sort of trouble. I used it to patch and then to line the tank on my Earthmaster, and it was very good. Gene Davis
Doug
06-17-2002 14:15:03
You can purchase special kits that repair fuel tanks. These have adhesives that are compatible with gasoline. I have had exellent sucess with the type that is two parts epoxy putty you kneed with your hand and spread on.
Trueby
06-19-2002 09:00:33
 Re: Re: Help with patching a gas tank in reply to Doug, 06-17-2002 14:15:03
Do you Know the brand name of any of these kits?
Thank you
Baggsy-Wy
06-19-2002 22:28:14
 Re: Re: Re: Help with patching a gas tank in reply to Trueby, 06-19-2002 09:00:33
Check with your local motorcycle shop, they have the kits on hand. It might take two to do a large tank, but they work quite well. I re-did a tank in BAD shape for an old hit and miss motor, and it did the trick and has been holding up well for 5 years now...
