Head repair gone wrong farmall h
jay dee
06-17-2002 17:38:22
i`ll keep it short
exhaust blowing white smoke
pulled head,had a little antifreeze on one piston
had head reworked all new gaskets fluids and all
not spark plugs yet but started it and back fireing thru carb got that settled down but whatever i do with it runs about half power
nomader if throtle is at idle or full open
i didn`t change nothing else first time post thanks fo any help
Mike C.
06-18-2002 12:24:16
 Re: head repair gone wrong farmall h in reply to jay dee , 06-17-2002 17:38:22
To start with, Ralph mentioned about the valve adjustment. If you did have the head planed and you didn't re-adjust the valves then they are too tight causing them to not close completely.
This might sound like a stupid question but are you sure you have the firing order correct, head touqued properly and head gasket lined up right?
Anyways, you said that you sent the head out and had it re-worked. You're doing things right and I don't imagine the problem is going to be a big one.
Don't panic. Remember the "KISS" principle (keep it simple stupid). Often times the problem is so obvious that we tend to overlook it. Take a step back and fix any obvious problems first.
jay dee
06-18-2002 17:49:08
 Re: Re: head repair gone wrong farmall h in reply to Mike C., 06-18-2002 12:24:16
first thanks for both returns
checked things over again found 3 pushrods
that were really loose, snugged them up
to manuals .002 gap runs really smooth
but still runs at half throttle all the time.
something messed up in the govoner?
again thanks for reply
Bob Weber
06-24-2002 12:56:12
 Re: Re: Re: head repair gone wrong farmall h in reply to jay dee, 06-18-2002 17:49:08
I don't know much about the Farmalls, but I'd think .002 is way too tight for a valve clearance.
Ralph 560 (MO)
06-18-2002 06:36:14
Did you have the head resurfaced? You could have a warped head or cracked as for the antifreeze. check your valve lash, you may have a valve or valves not closing all the way.
rhouston
06-19-2002 13:46:12
 Re: Re: head repair gone wrong farmall h in reply to Ralph 560 (MO), 06-18-2002 06:36:14
was the governor hooked back correctly?
jay dee
06-19-2002 17:10:47
 Re: Re: Re: head repair gone wrong farmall h in reply to rhouston, 06-19-2002 13:46:12
yes we were getting in a hurry
trying to get done,putting on the exhaust manifold
and carb it was bound up, today i checked it
seated it right all is good except adjuusting
the carb and putting on a new seethru gasket
that is leaking
THANKS TO ALL this board really works
jay dee n.w.ohio
