Hyd. valve and cylinder
Gary Cole
06-23-2002 12:09:28
Thanks Alton and JMS. How hard is it to install a hyd. valve on a 65 Massey for hyd. for a bog disc or whatever else I might need? Is there a fitting under the seat? What size cylinder would I need to make a 3 point hitch for a C Farmall? Thanks
JMS/MN
06-25-2002 22:42:19
 Re: Hyd. valve and cylinder in reply to Gary Cole, 06-23-2002 12:09:28
You're welcome. As I remember, a 65 Massey was a common field tractor not too many years ago, And I understand you want to install a remote hydraulic cylinder coupling on the tractor. That was certainly common for that era, so I would imagine any dealer ( now AGCO) would be able to help you with that project. I'm surprised that yours does not already have one, but certainly it should not be hard to tap into a line with continous pressure, and run a return line back to the resevoir.
Alton
06-25-2002 19:11:11
On the cylinder you have to determine the weight you are going to be lifting, the flow per minuite of the pump and the speed you want the cylinder to lift and the length of travel.
