Bent pto shaft on AC WD
Geoff
06-24-2002 12:34:39
My pto shaft has about 1/2 inch wooble at the splines. The long section from the pto drive coupling to the carrier bearing appears to be straight, so the bend appears to be on the spline side of the carrier bearing.
Should I replace the shaft or can I repair the old one? Any ideas on how to straighten the shaft and check for true myself?
JMS/MN
06-25-2002 22:34:50
 Re: bent pto shaft on AC WD in reply to Geoff, 06-24-2002 12:34:39
Take it to a machine shop or anyone else with a press and straighten it- run it on v-blocks to check for true. Would be a good idea to remove the carrier bearing, and straighten the whole shaft. Makes it easier to block it in the proper spot to correct the misalignment.
