Delco Remy Starter Parts
Tom
06-27-2002 20:07:44
I am looking for help finding parts for the delco remy starter on my 1945 Farmall B. Specifically I am looking for a part to replace the existing foot operated starter switch that is mounted on the starter houseing. I am converting the electrical system to 12 volt and would like relpace the switch with a stud and use and exsternal starter relay for added security and safety. I know that the part existes because I have seen other makes of tractors equiped with deloc starters that had a stud instead of the foot operated starter switch and that use an external starter solenoid. I have looked in the NAPA Echlin book, but have been unable to locate the proper part. A suplier or part number would be exstreemly helpfull.
Thank you for your help!
Jimmy Foster
05-31-2003 15:12:11
 Re: Delco Remy Starter Parts in reply to Tom, 06-27-2002 20:07:44
Have a 55 Oliver starter #1108610 5H15, I Am looking for a solenoid switch.Don`t know where to go find one. Thanks, Jim
Jim in UK
08-27-2002 05:29:19
Try going to your local NAPA Parts Store. If they can't help you out they will most likely know someone that can.
jake
06-30-2002 02:11:44
I had the same problem till I located a 12 V replacment,I used the original push type and made a U shaped strip of sheet metal, compressed the spring then used pop rivets to hold it down. The solenoid was then connected to the closed switch worked well. A new stud might be found at an aut-electric shop and due to the fields being soldered or brazed they would be better to do the job.
John Ne.
06-29-2002 06:45:34
Somewhere around there should be someone with a pile of old Delco starters, even automotive type. Am sure you could scavenge what you need from a used one. Don't see where you would gain in the safety aspect? Always liked the simple method of that rod operated starter, tho. John
