Need help un seizing a gas caterpillar 15 motor
lars
06-28-2002 11:52:50
how do you un seize a 4 cyl gas 1930 caterpillar engine? I can't buge the crank at all. It's been sitting for awhile.
Alton
07-02-2002 18:09:41
 Re: need help un seizing a gas caterpillar 15 motor in reply to lars, 06-28-2002 11:52:50
Piston rings are more then likely stuck to cylinder walls. Take out spark plugs and put some good penetrating oil or diesel fuel in the cylinder throught the plug holes and let soak for a few days then try to bar it over. The longer the soak the better. If this doesn't help you may need to take the head off and jar the piston to get it loose. Sometimes this is not hard and sometimes you end up breaking pistons to get free.
Good luck!
