Axle repair, groove
Super 55
06-29-2002 10:11:14
Posted on Tractor Talk, but I guess this is a more direct discussion group.
For my first tractor restorationI am restoring an Oliver Super 55 and I have the final drive disassembled to replace the bearings, seals, and brakes. I noticed the axles each have a slight goove where grit or rust got under the seal or bearing surface and made a groove. I seem to remeber a posting ages ago that mentioned using JB Weld to fix, but I have also heard of spray welding. Would be interseted in others comments and advice. Thanks in advance.
GeneDavis
06-30-2002 18:36:11
 Re: Axle repair, groove in reply to Super 55, 06-29-2002 10:11:14
Conssider going to the local bearing supply house and consult with them about the speedi-sleeve repair process for shafts. Gene
