273 hayliner
wade
07-02-2002 10:59:03
I have a New Holland 273 baler and I just can't seem to get the slight banana shape out of my bales. Works great otherwise. I try to keep the windrows even and have pretty decent hay to feed it. Any suggestions?
Glenn Neumann
08-24-2002 06:56:18
 Re: 273 hayliner in reply to wade, 07-02-2002 10:59:03
I have NH275. have had similar problem until I replaced bottom bearing on plunger (right next to blade) I had to push the plunger out the bale shoot. Then I followed manual adjustments for alligning plunger. (actually I started with trying to do alignments but could not get full adjustment as the bearing wobbled). now, no bananas!
ken
07-20-2002 20:44:35
I hope you figure it out.I run a 275 NH and have done everything that can be done and still have banana shaped bales. good luck.
Alton
07-02-2002 17:48:46
Some of the new holland balers have four hay fingers that push the hay in the chamber and some have six. The ones with six do a beter job of pushing the hay more even in the bale chamber. The ones with four tend to push more hay into the left side facing the direction you are traveling. If the bales are shaped long on the left and short on the rignt this may be the cause. If they are banana shaped up and down then you may need to tighten the tension on the bale chamber.
Cim in Idaho
07-07-2002 23:08:55
 Re: Re: 273 hayliner in reply to Alton, 07-02-2002 17:48:46
Also make sure you don't have any broken or excessively worn fingers ... you can get all kinds of weird-shaped bales if you do! Cim.
