Re-Metaling of bearings and bushes with white metal
Cliff Tyson
07-03-2002 11:05:49
Is there anyone in the United States who can tell me the best way to re-metal bearings and bushes with white metal (re-babbitting?) I live in Zimbabwe and only the basic equipment for soldering is available. For example, spirits of salt is a tinning flux, more sophisticated fluxes are not available. White metal is available in various grades. If anyone can tell me a very basic but successful method, I will be extremely grateful.
Thank's in advance.
Best regards
Cliff Tyson
Dennis Benson
07-15-2002 11:38:08
 Re: Re-Metaling of bearings and bushes with white metal in reply to Cliff Tyson, 07-03-2002 11:05:49
Hello,
Check this book for sale at>Link
Dennis Benson
Gene Davis
07-11-2002 06:50:12
Used to work at a machine shop years ago and we repoired bearings for sawmill shafts this way. We melted out old bearing material (babbit,the more tin in the babbit the higher speed raring on the bearing), then we cleaned the housing,roughened it up slightly for the babbit to adhere to. We had short pieces of the correct diameter shaft that we used to get the correct inside diameter of the bearing. We took the shaft and completly covered it with a layer of sooty residue from the acwtylene torch burning acetylene with very little or no oxygen, you could probably use lamp smut, what you are doing is creating some to keep the high temp metal from bonding to the shaft, most oils and grease will burn and contaminate the mix, we had best results from smutting the shaft. We placed an equal number of shims on each side of the bearing half to allow it to be removed to take up some of the wear after the bearing ran for a while. You need to make sure there is NO Moisture, as moisture causes the metal to spit back violently!! We then built a fire proof dam on one end of the housing,don't know what to tell you to use here, since we used asbestos material at that time,(been45yrs. We usually stood the bearing on end when ever possible, to pour it easier. The beaing metal, or babbit as it was called here is melted in a cauldorn or a ladle over heat and skimmed to remove all impuruties ,you do not want to have a roaring fire, just steady heat that is hot enough to melt the metal, spatters of this will cause TERRIBLE burns, be sure that no moisture or oil gets int othe metal. It is important to remember that once you start pouring that you have enough bearing metal to pour the complete bearing non-stop, or else you will not get a soild bearing, every time you interrupt it the bearing becomed layered, or worse has air pockets in ot and the metal is not solid in the bearing. Keep pouring slowly till the metal fills up the housing and over flows slightly, let cool to the touch, then disassemble, keeping shims in the right, remove the sizing shaft piece,trim the excess bearing material off ends and sides ,drill the necessary lubricating holes, or in some cases oil grooves. The bearing should be ready to re install. Hope this helps Gene Davis Tennille Ga. U.S.A.
Cliff Tyson
07-11-2002 08:31:39
 Re: Re: Re-Metaling of bearings and bushes with white metal in reply to Gene Davis, 07-11-2002 06:50:12
Thank you for your help Gene. Did you have to use any type of flux to make the babbit adhere to the bearing housing?
Best regards
Cliff Tyson
John Ne.
07-15-2002 17:01:53
 Re: Re: Re: Re-Metaling of bearings and bushes with white metal in reply to Cliff Tyson, 07-11-2002 08:31:39
Generally not, there is usually a pin in the housing to keep the bearing from spinning, have tried fluxing the housing, but checked later and bearing was loose and removable, but running without problems. john in Nebraska
Cliff Tyson in Zimbabwe
07-16-2002 09:20:40
 Re: Re: Re: Re: Re-Metaling of bearings and bushes with white metal in reply to John Ne., 07-15-2002 17:01:53
Thanks for your reply John. On compressors there are steel backed bearings or bushes which are lined with white metal. Same idea as the big-end and main bearing shells on a standard car engine.
Best regards
Cliff Tyson
