Case Model 500 Dsl
Darrell wood
07-04-2002 20:20:13
Need help: I am a novice deisel tractor owner. Finally got a 500Dsl running, but the governor sticks. Somebody told me this is the first Case deisel. Any info about how to correct sticking governor greatly appreciated. I would purchase an owner's manuel but not sure which one to buy.
Serial # 8040947.
RobertTX
07-08-2002 05:48:54
 Re: Case Model 500 Dsl in reply to Darrell wood, 07-04-2002 20:20:13
I don't know much about the governor on these, but when I first got my 500 running, the pump shutoff had problems which were apparently due to being gummed up and the tractor ran rough also. Clean filters and a few gallons of fresh fuel with additive run through it made a lot of difference. Unless it's doing something that could be dangerous or damage the engine, it may just need to be run some.
Darrell Wood
07-09-2002 08:25:00
 Re: Re: Case Model 500 Dsl in reply to RobertTX, 07-08-2002 05:48:54
RobertTX,
Thank you for the kind advice. I shall follow your suggestion to run additive through. A neighbor who is a retired deisel mechanic told me to run a pint of automatic transmission fluid through by filling a filter container. I wonder if anyone has done this.
I had not started old "Orange Crush" for a couple of years, so I am sure gum is a problem. I use her to launch and recover a sailboat, and need her this year for Lake McConaughy where I live is very low from a drought--little water came down the North Platte River out of Wyoming.
Darrell wood
07-05-2002 22:08:13
I have a governor that sticks on a 500 deisel. Please send suggestions to remedy.
