Penetrating oil
Tom L.
10-29-2001 22:39:01
Normally, I don't endorse products unless they are REALLY good. I was talking to a co-worker of mine the other day about my restoration project and that I was having a problem with some rusty nuts. He recommended a product called "S'OK!" It is made by Shamrock Specialties,Inc. P.O. Box 1369 Palestine, Texas 75801. I got some and tried it first on the exhaust manifold nuts. I figured they would twist and break for sure. I gave each one a shot, waited 10 minutes and they came right off with little effort. Next I tried it on a ball joint jam nut that I had tried earlier with a breaker bar with a 4' cheater on it and it wouldn't budge. One shot, wait ten minutes and it came off with a regular socket wrench and no grunting! You got to try this stuff- it really works! It might be hard to find, but a good auto parts dealer should be able to get it.
John Culp
12-29-2001 12:03:34
 Re: Penetrating oil in reply to Tom L., 10-29-2001 22:39:01
I'll second that recommendation for S'OK! It works far better than anything else I've tried. I'm about to run out and need to find some more! (I got it from a friend at the Portland engine show. I haven't seen it here in Bristol, Tennessee yet otherwise.)
Mike (IN)
11-14-2001 19:51:56
I've found that Pro Long has an outstanding penetrating oil, too. It was the only thing I found that would loosen the manifold bolts on my CA. It's worth the $25 to buy the full set of products, too. I used the gas, oil, and transmission treatments in my H, last spring, and found I could plow in areas, where before, it was unable to pull it.
300 Randy
10-30-2001 05:25:58
Try PB Blaster it works really good to. I had a nut I was soaking with WD-40 for weeks with no luck. PB Blaster loosened it up in a couple of minutes. Could be that these two products are pretty much the same.
