Popping out exhaust now
Alvin Turner
07-06-2002 14:46:00
Set the valves. Fine tuned the timing. Now it is popping out the exhaust on top. Nothing coming through the carbureator now. Have 90 lb. pressure on all cylinders. What else cn it be?
Alvin
Alton
07-06-2002 15:16:42
 Re: Popping out exhaust now in reply to Alvin Turner, 07-06-2002 14:46:00
Sounds to me like you are not getting the crank in the proper position to adjust the valves, and the valves are not adjusted correctly. There should be a timing mark on the flywheel. If it was poppong out intake then you adjusted and it is poping out exhaust, it sounds like you are adjusting incorrect. Is this all you changed? The compression test should not be the same on all cylinders if it is poping out the exhaust. You could have retarded timing but should pop out of all cylinfers. A bad plug wire could do it, Change the plug wire to anouther plug seperate the wires fo they don't touch one another.
Alvin Turner
08-04-2002 12:20:52
 Re: Re: Popping out exhaust now in reply to Alton, 07-06-2002 15:16:42
We finally got it worked out. Replaced the carb.
