Farmall F-14 Timing gear cover oil seal replacement
John
07-08-2002 12:05:48
On my Farmall F-14. How do I remove and replace the oil seal from the timing gear cover?
Karl
09-18-2002 11:13:17
 Re: Farmall F-14 Timing gear cover oil seal replacement in reply to John, 07-08-2002 12:05:48
Drive the pin out of the end of the crankshaft. Unscrew the big nut. Pull the pulley; it may or may not have a couple of threaded holes which can be used to push it off. Usually they aren't on very tightly.
Remove all of the bolts holding the front cover on. Lay the cover face-up on a couple of boards and use a punch on the far side of the seal to drive the seal out. It comes out of the inside of the cover. Replacements are available from NAPA, among other sources.
