IH 300 utility running at full throttle
dave
07-16-2002 07:57:13
just rebuilt carb which was leaking fuel, put back together and she started right up EXCEPT she is at full throttle and i can't slow her down without shutting off. Help please
Bill Hires
07-16-2002 08:36:19
 Re: IH 300 utility running at full throttle in reply to dave, 07-16-2002 07:57:13
Remove the throttle shaft housing and check to see if the throttle shaft is synchronized with the throttle butterfly. The pin must go into the shaft in the correct position, or you will get either a wide open, or closed butterfly. There is a possibilty the throttle stop screw is in the wide open position, also. Back it off if this is the case.
Don LC
07-16-2002 08:26:14
I am guessing that you don't have the govener rod that controls the throttle plate in the notch.. ....Thats the little square notch on the govener rod that goes into the notch in the "white" plastic piece on the end of the throttle plate,rod....
dave
07-16-2002 10:43:35
 Re: Re: IH 300 utility running at full throttle in reply to Don LC, 07-16-2002 08:26:14
thanx bill and don, you are both recommending the same. I will give it a try tonite and let you know how I made out. Thanx again
dave
07-17-2002 03:54:06
 Re: Re: Re: IH 300 utility running at full throttle in reply to dave, 07-16-2002 10:43:35
You guys probably knew i was not a mechanic based on my question but i sure feel like one thanks to you. Followed your advice and she runs great!!
Thanks again to Bill and Don
