Converting a early 1950s cub from 6 volt to 12 volt.
cliff johnston
07-20-2002 14:09:06
I had requested this info some time ago and received an answer quickly which included a full diagram and parts list. Unfortunatly I had this info stored on a computor I no longer own. Therefore this info is lost. (so much for a paperless world!)
Can anyone resend this info to me? I promise to print off so it will not be lost again.
I have researched articles on this subject but they are too general. With my limited knowledge I need very clear instrutions. Thanks for your help.
Cliff
Don LC
07-21-2002 07:44:15
 Re: Converting a early 1950s cub from 6 volt to 12 volt. in reply to cliff johnston, 07-20-2002 14:09:06
Cliff --- The information you are looking for is in the "RESEARCH & INFO." If you will look on the left side of this page you will see a list of subjects.....Go down to "RESEARCH & INFO",right under it you will see ...ARTICLES..click on it....scrole down about 18", you will find STEP BY STEP 12v CONVERSION -- by Bob Melville....this is for a M , but it will work on your CUB also.....I found the small pully,2"x5/8"shaft at Tractor Supply.they also have 1 1/2",thats the one I am going to try.....Good luck.....
