Freeing stuck pistons
Lenn
07-25-2002 14:29:25
Don`t know if this is the right place to post this,but wanted to share a idea that has worked good for me. Use at your own risk of course.
You need to have the head off and be able to place the cyl. in a vertical position.
Take a piece of rag and lay in the center of piston,then pour about a 1/2 inch of brake fluid in cylinder on top of piston.
The rag will act like a wick,light it and let burn for 3-4 hours,the brake fluid burns real slow and will penetrate very well when hot,plus it heats up the cylinder.
I have freed some very stuck pistons on large gas engs. this way.
Hope this helps someone out.
wayne from west oz
08-03-2002 00:25:42
 Re: Freeing stuck pistons in reply to Lenn , 07-25-2002 14:29:25
thanks for your tip ill try it
Tugboat
08-02-2002 18:13:16
Lenn; Sounds like a good idea. I have used a block of wood and a piece of heavy channel iron. Drill the channel iron for one head bolt on each side on the cylinder and screw the iron down against the wood block on top of the piston. Use hot brake fluid in the cylinder. A little patience and it works real well. Thanks again! Tugboat
