Hydraulic Pump Rebuilders...1956 Ford 640
Steve Rey
08-06-2002 06:15:23
OK..I decided to rebuild my Ford 640 hydraulic pump. Not a bad job, pretty simple as a matter of fact. However, the kit I have has a couple extra parts in it. Looks like two sets of piston springs, one small one large. Mine uses the large springs. Also, two gaskets one used with the small spring one with the large.(at least that's my assumtion)
Of coarse also included were the check balls and springs, front seal, plate, and other gaskets. Now for my problem, in the kit were some seats for the check balls. After looking at the housing where the seats would go it does not look like they're inter-changable. The seats in the pump look to be part of the casting. I called a dealer and they said the seats are replaceable and that you need a special tool. Again, I looked very carefully and came up with the same conclusion the seats are not changeable. Can some one help me out here. The kit obviously contains some parts not used in my pump.
WALTER
02-11-2003 15:20:31
 Re: Hydraulic Pump Rebuilders...1956 Ford 640 in reply to Steve Rey, 08-06-2002 06:15:23
I HAVE A 601 FORD,AND REBUILD THE PUMP AND THE SEATS IN IT ARE REPLACEABLE.BUT THEY ARE 2 DIFFERENT KIND OF PUMPS ON THESE TRACTORS.
