F-20
Chris
08-14-2002 08:50:46
I got my F-20 started now, 5 of the 8 valves were stuck so that was why it wasn't starting, and now that i got it started it will run for about a minute or so and then the power leaves and it starts to blow flames out the exhaust and then it will quit. I'd appreciate any help or info as to why its doing that. Thanks in advance.
Chris
Don LC
08-27-2002 08:22:38
 Re: F-20 in reply to Chris, 08-14-2002 08:50:46
Chris --- some of the exhaust valves are not closing all the way...when it fires some of the fire is getting past those valves and out the exhaust pipe... remove the valve cover and spray WD-40 on all of the valve stems.Do this several times a day for 2 or 3 days .....Add a "VALVE TOP OIL" to the gas tank...Start it up and spray the valve stems as they go up and downIf this works put the valve cover back on.. keep it running,let it sit and run at 25% throttle for at least one hour ....CAUTION WATCH DON"T LET IT OVER HEAT>>>>>Use this oil for several tank fulls of gas....If this doesn't work ,have the valves ground.....
