How can I tell when a engine need a rebuild
Learning
08-16-2002 18:58:36
What are some of the signs a engine needs to be rebuilt?
Thanks for your time and help
TimC
09-06-2002 14:14:03
 Re: How can I tell when a engine need a rebuild in reply to Learning, 08-16-2002 18:58:36
Hope this makes sense but here goes.
Is it worth it?
Does it matter?
Can you put up with the smoke or low power or noise.
Provided it is still in good mechanical condition
you don't usually have to spend the money until it is convient or justifiable.
JMS/MN
08-22-2002 16:53:12
Along with other comments- do a compression check on each cylinder. Look for wide variation in readings, or all readings being low for your engine, per tech manual. Fouled plugs indicate bad rings, broken rings, excessive wear, etc. If the engine is open, measure jugs for excessive diameter, out of round, beyond specs. Excessive clearance on main and rod bearings, camshaft, etc.Worn timing gears, chains. Slow starting when ignition parts are good.
Bigdog
08-17-2002 04:06:44
There are several things that might indicate the need for a re-build. Decreased power, increased oil consumption, rattles, noises, blow-by (smoke out of the crankcase breather or oil fill tube), smokey exhaust, decreased compression, the sparkplugs foul often. The list goes on and on. Another factor would be age and whether or not routine maintenance had been done over the life of the engine.
DavidO...but
09-18-2002 12:14:23
 Re: Re: How can I tell when a engine need a rebuild in reply to Bigdog, 08-17-2002 04:06:44
If it cranks easily and runs good,pulls pretty strong, doesn't smoke too much and doesen't make any unusual noises, IT DOES NOT NEED A REBUILD. Do something else to it, or do something else with it. Enjoy.
