Sodium...in my tires!?
Doug
08-20-2002 19:22:35
I'm restoring an old Massey. The tubes in the rear tires were filled with what I was told was "sodium." When I pumped it out, it was a clear/milky and oily liquid about the consistency of hydraulic fluid. Smells a bit like salt, and it sure rusted the heck out of the rims. I had to weld up the valve holes they were rusted out so bad. My question: what is this stuff? Is it toxic? Now that I have a 55 gallon drum of it, how do I get rid of it safely?
Tom A
08-26-2002 05:24:31
 Re: Sodium...in my tires!? in reply to Doug, 08-20-2002 19:22:35
Sodium chloride--salt. Mixed with water and used to add weight to tractors to increase traction. The mix doesn't freeze, was cheap and dense. Nowadays many folks use antifreeze for the same purpose, although the salt mix is heavier for the same tire size.
I know some old timers spread it along fence rows to keep weeds down. Most places that repair tractor tires deal with it, and you might be able to pay one to take it from you.
good luck,
Tom
JMS/MN
08-22-2002 16:49:16
Check with local tire shop to see if they will take it off your hands. No pun intended! Can probably donate it to someone who needs ballast.
Frank M.
08-20-2002 19:47:13
More than likely it's Calcium Chloride. Bad for metal, leather, and skin. Not exactly toxic but don't pour it in a place you want to plant anything for a year or two. I fixed a flat on one that had caustic soda in it. That's also known as Sodium Hydroxide, or Lye. It's even worse on your hands. I don't think it's a problem to just dump it on the ground, but I'd ask an expert before I did it.
Just another thought. Some of the guys are fixing up electrolysis baths to remove rust, and it uses sodium hydroxide. Hope this helps
Frank M.
