Farmall M stuck in gear
Z.J.
08-21-2002 17:14:56
My Farmall M seems to be stuck in gear - any ideas on how to get it loose?
Wayne
08-27-2002 06:24:20
 Re: Farmall M stuck in gear in reply to Z.J., 08-21-2002 17:14:56
The end of the shifter may be worn. You may consider having the end built up to fit into the slots. My Super M was the same way. Not an unusual problem.
Don LC
08-21-2002 20:09:38
Remove the shift lever...Now with a large screw driver move all the shifting forks in line,too geather replace shifter....somebody is speed shifting your tractor.....
Ronald
02-15-2005 18:29:13
 Re: Re: Farmall M stuck in gear in reply to Don LC, 08-21-2002 20:09:38
My M did this once Ijust rocked the tractor back and foward and it released. Never has done it again.
