Off-season tractor battery maintenance?
polk crawler
08-30-2002 13:54:53
What is the best way to maintain a battery in off-use season? Will a trickle charge be OK? Read somewhere battery should NOT be put on a concrete floor. Why?
If battery is left in the tractor,will disconnecting either cable insure against a draw down if there is a current leak somewhere?
rhouston
09-05-2002 13:00:33
 Re: off-season tractor battery maintenance? in reply to polk crawler, 08-30-2002 13:54:53
I like the idea of a solar trickle charger, but have not bought one or used one. clean top of battery before storage as acid and dirt can conduct electricity between battery posts.
meihman
09-03-2002 12:03:31
I take my batteries out for the winter. I put them in my basement on a 2x8. The wood keeps them off the cement floor. It is because of the moisture content in the cement that causes batteries to drain. I re-charge them in the spring.
Red Dave
09-03-2002 06:22:24
I don't take the batteries out of the tractor and I don't trickle charge. The shed they are in is unheated and yes, it does freeze in Pennsylvania. As long as the electrical system is working properly and not draining the battery, I don't see a reason to remove it.
All I do is give the battery a good soaking charge for 6 - 8 hours every month or so. Usually while I'm outside working on something else.
One 6 volt battery I have was bought in the fall of 1994 and still works OK.
CNKS
08-31-2002 19:26:38
The concrete floor thing does not apply to modern batteries--has to do with the materials used, don't remember the details. If you disconect the battery ground cable, you shouldn't lose charge. I like the idea of a trickle charger.
Redtractorman
08-30-2002 21:39:25
I take out all of my batterys and put them on shelf in garage hooked up to a 2 amp trickle charger.Bought about half dozen of these from Harbor Freight for $7.00 each and they work great.
Rick T
09-06-2002 18:29:21
 Re: Re: off-season tractor battery maintenance? in reply to Redtractorman, 08-30-2002 21:39:25
How long can a trikle charger be used? Can it stay on the battery all season?
