HYD FORD JUBBLEE(OVERHEAD VALVES)
JOHN
09-03-2002 08:20:05
BOUGHT TRACTOR ABOUT 2 YEARS AGO. HYD JUMPING WHILE RAISING ONLY. WE HAD LIHT COVER OFF AND RENEWED VALVING AND RESET DRIFT CONTROLS FOUND A PEICE OF STEEL(BARRAL)IN ONE OF THE VALVES. HYD PRESSURE ONLY 600PSI.
GETTING READY TO CHECK SYSTEM RELIEF PRESSURE TO SEE IF ITS LIFTING OR LEAKING.
QUESTION; WHAT ARE THE CHANCES OF THAT PEICE OF VALVE OR SOMETHING WE FOUND IN VALVE UNDER LIFT COVER BE PART OF A INLET OR OUTLET VALVE OF PUMP?
THANK YOU FOR YOUR INPUT.
100% chance
09-03-2002 19:31:57
 Re: HYD FORD JUBBLEE(OVERHEAD VALVES) in reply to JOHN, 09-03-2002 08:20:05
These lifts jump like that when the pistons in the pump,are giving out$$$$$$$$$$$
