Case va poor off idle and no power.
kevin duenk
09-05-2002 09:38:13
please help me.i am a junoir farmer trying to help my father-inlaw.I have a 1942 case "va".it will idle great but as i increase rpm's it starts to run rough and stall.I had the carb. apart and cleaned.If I richin it up it doesn't make any difference.I've replaced the points and dist. bushings.I know the engine has been recently been rebuilt.It ran well last year.Spark seems to be strong.If any body could help me it would be appreciated.I would like to have my father-inlaws respect again.
Jerry B
09-06-2002 07:00:53
 Re: case va poor off idle and no power. in reply to kevin duenk, 09-05-2002 09:38:13
Make sure you have sufficient gas flow to the carb from the fuel tank. You could have a plugged line or hose. That will cause starving.
Make sure it is timed correctly. Timing set too high will cause the engine to miss and run very rough as rpm's increase due to the distributor advance weights advancing the timing even higher.
Also, make sure the points are set properly and and making full contact with each other. This affects dwell time and coil saturation.
