NAA oil change
Michael
09-24-2002 07:32:38
Changed the oil and filter but oil leaks from end of canister at the bolt head/rubber washer. I didn't tighten too much but added a little pressure when the leak did not stop. Any one have a suggestion on how to correct this? Did I fail to replace an interior gasket? I'm ready to cut a small rubber washer and add it to the larger exterior washer. Thanks
IanC
09-25-2002 18:15:01
 Re: NAA oil change in reply to Michael, 09-24-2002 07:32:38
Once rubber washers have been hot they usually don't seal well. OEM filter (p/n 86546608) comes with a new rubber washer for under head of bolt. Also available is a kit to convert to spin on filter, I can't remember p/n but any New Holland dealer should be able to order it for you ( I usually even stock one).
