Coil resistor
bill w
09-27-2002 18:04:33
will a 12 volt resister (delco 1106 )work on a 6 vlts system to drop the voltage to 3.65 ? i cannot find one to soon enough, need tractor to run now . keep burning out coils staight 6vts to much.
steve
09-29-2002 18:17:20
 Re: coil resistor in reply to bill w, 09-27-2002 18:04:33
Bill, all coils from the 1940-50 eara were 6 volt. in the 1960s they either added an external resistor, or an internal resistor to the old 6 volt coil to make it "12 volt". a 12 volt coil is really a 6 volt winding with an internal resistor. to answer your question, a 6 volt coil is a 6 volt coil and dont need a resistor. if you continue to burn them out, might want to try changing out the condenser and setting point gap (maybe a new point also).
