Checking a voltage regulator
jimbob
10-01-2002 11:21:25
How can i check my voltage regulator to see if it's working right?
emerson arcita
05-10-2004 01:15:00
 Re: Checking a voltage regulator in reply to jimbob, 10-01-2002 11:21:25
how to check voltage regulator of philips
steve
10-02-2002 18:36:52
on the generator there are two terminals, A and F. Remove the F terminal wire nad short the terminal to ground. remove the A terminal wire, and jump it to the battery terminal. start tractor and measure the voltage across the battery. if it is 13 volts (or so---13.8) the generator is good. now put the regulator back in the wiring with the F and A terminlas. start motor and measure the voltage across battery again. should still be 13.8 - with motor off you probably still have 12.5 with a full charge. if you dont have a digital volt meter, you might be able to put the amp meter in line and see how it reacts.
