Transmission locked in Reverse
Ajackr
10-02-2002 16:39:37
I have a 135 Massey Fergerson and the transmission locked in reverse today. What is the best way to fix the problem. I am open to any and all sugestions.
TAB
10-07-2002 00:04:24
 Re: Transmission locked in Reverse in reply to Ajackr, 10-02-2002 16:39:37
Masseys are prone to this happening. More than likely it happened because you were probably pulling up on the shift lever while shifting..... .which is easy to do. Try to remember to do your shifting without pulling up on the shifter knob. And, like a previous post suggested, the easiest way to fix it is to take off the filler cap and get a long and strong srewdriver and wiggle the gears around until it frees up. Sounds like you have done that, though. :) All tractors have their little quirks.
Ajackr
10-06-2002 13:45:11
My thanks to Both Don LC and Johnny B: The tractor is back in opperation and working normally again. who said an old dog can learn new tricks.
Don LC
10-02-2002 17:53:04
Remove the shifter from the transmition....with a long ,strong screwdriver, move the shifting forks into neutral,replace shifter..... look at the end of the shifter,if the end shows wear,weld it back and grind it to shape..... .
Ajackr
10-03-2002 09:35:28
 Re: Re: Transmission locked in Reverse in reply to Don LC, 10-02-2002 17:53:04
I removed the pin from the base of the shifter, or the from the nut and the shifter, but unabe to unscrew the nut from the top of the transmission. Any Ideas on that? it turns but doedsn't seem to have any threads,
JohnnyB
10-03-2002 17:32:15
 Re: Re: Re: Transmission locked in Reverse in reply to Ajackr, 10-03-2002 09:35:28
I always remove the filler cap (about a 2" pipe plug right beside the gear shifter) and reach in there with a tire tool and push the gears around until it straightens out.
