Cracked lower radiator tank
68 Fish
10-07-2002 20:56:19
Im restoring my 49 cub. The drain plug was rusted and wouldnt budge. Heated it up with the torch and she came out nice and easy. 5 min later, CRACK!! The lower tank (cast) now has 2 hair line cracks about 1 inch long each radiating from the drain hole. Do I have to take this to a welder or has anyone used JB.Weld or a product called Marne tex. My Idea it to use my dremmel or diegrinder and make a valley out of the crack and fill it in. Has anyone tried this??
RobertTX
10-09-2002 05:23:28
 Re: cracked lower radiator tank in reply to 68 Fish, 10-07-2002 20:56:19
Those cracks probably will not be a problem. I don't know anything about the Cubs, I am assuming it is a 0 psi cooling system? Clean it good, JB weld, it should be fine. One thing to check before you JB - put a new plug in to see if it causes the cracks to grow or expand. If it does drip after reassembly, one of the stop leaks will hold it. If it is a pressurized system, or you plan on putting a lot of hours on the tractor, might want to look at a profesional fix, otherwise, it will be OK. Many old tanks with cracks are holding coolant. The rust covers the cracks and makes a good sealant.
