Wideing my front axles
68 Fish
10-07-2002 21:00:58
Whats the easiest way to widen the front tube axle on the cubs?? If you heat her with a torch do I have to worry about it cracking like my lower radiator unit did?? My axle at this time is at the shortest position. I would like to take it out at least one notch wide.
Thanks
Redtractorman
10-08-2002 08:28:47
 Re: wideing my front axles in reply to 68 Fish, 10-07-2002 21:00:58
I would loosen bolts and soak with good penatrating oil and use the tractor that way for a few days,this usually loosens them up so they can be moved with less effort.I would use heat as a last resort only.
Don LC
10-08-2002 05:30:27
Remove the adjusting bolts and clamps or blow them off with your torch..... ....I think the tubes are slotted.....use a large brass drift pin and try to widen the slots.....very very,little soak ,with WD-40.....this might take a few days.....If you get new bolts ,get grade 5.....
yes
10-08-2002 01:16:05
if your axle is made out of an old radiator.
