AC WD
KAL
10-13-2002 18:09:16
IVE GOT A 1953 AC WD I CANT GET TO FIRE IT HAS GAS AND SPARK THERE IS A WIRE ON THE MAG I BELIVE IT IS A KILL WIRE IT GOES UP TO A SWITH THAT NO LONGER WORKS THE WIRE IS NOT HOOKED UP .SHOULD IT BE HOOKED UP TO COMPLEAT A CIRCUIT?ANY INFO WOULD BE GREATLY APRECEATED THANKS KAL
JMS/MN
10-14-2002 23:46:22
 Re: AC WD in reply to KAL, 10-13-2002 18:09:16
Disconnect that wire at the mag and see if it starts. It does go to a kill switch, and by completing that circuit, the engine dies.
KAL
10-16-2002 13:50:48
 Re: Re: AC WD in reply to JMS/MN, 10-14-2002 23:46:22
JMS/MN THANKS FOR THE REPLY I HAVE THE WIRE OFF AND STILL NOTHING.IF THE MAG IS IN 180deg OUT WILL IT BACKFIRE LIKE A CAR WOULD?THANKS KAL
JMS/MN
10-20-2002 20:02:31
 Re: Re: Re: AC WD in reply to KAL, 10-16-2002 13:50:48
Backfiring is a possibility- even if it is not 180 degrees out. Spark plug wires could be installed wrong. Firing order is 1243, but you need to establish which wire is on #1, then go clockwise as viewed from the rear. (Magneto setup). Distributor is vertical orientation, and you need to follow its rotation. Check archives for info to determine when #1 cylinder is in firing position.
Punchie
10-17-2002 19:08:53
HI Kal
Go to the Allis Chalmers Forum, and look for this post " Mag problem update [+] - Jim-IL 08:20:55 10/11/02 " Read through it and if this does not help Post your question in that forum.
Good Luck !!
Punchie
